Free Eager Beaver chainsaw
Old 07-20-12, 07:07 AM
B
I've run into something i've not seen before on a 2 cycle engine.I have an eager beaver chain saw and the fuel is running out of the muffler on it when I try to start it.
I've adjusted the carb (zama) to almost no turns out on both the idle and high speed and it still does the same thing. Any ideas. I've seen this on 4 cycle engines but never a 2 cylcle.
Old 07-20-12, 09:52 AM
cheese's Avatar
Received 122 Upvotes on 112 Posts
The carb needs repair, something inside is leaking.
Old 07-20-12, 10:26 AM
B
carb is leaking
Thanx, Cheese,yeah I'll pull it apart again. Ruined another pair of pants in the ordeal.When i said the fuel was coming out of the muffler, I really meant it!!!
Old 07-20-12, 11:12 AM
Diaphragm pushing on needle, not allowing it to seat and fuel just keeps a running.
Old 07-21-12, 04:47 AM
Received 30 Upvotes on 29 Posts
If you have that much fuel flowing out of the muffler, the crankcase is really flooded. In addition to the carburetor repair look at the vent on the gas tank cap. If that is plugged, the tank would build up pressure in this heat we've been having and force the fuel past the carb and fill the crankcase.
