flash generator
Old 07-20-12, 03:50 PM
flash generator
I have a 1998 Generac Mega 2500 generator with a briggs & stratton engine. it puts out 10 volts on the 120a/c side. tried 'flashing' the generator using an extention cord with 12 volt battery. lost voltage down to 2.5. this is a brushless generator with a new capacitor. any suggestions?
Old 07-20-12, 04:39 PM
lawrosa's Avatar
Super Moderator
Received 79 Upvotes on 71 Posts
Some I think you don't flash like that. On my Briggs you use a electric drill.
It says plug drill in to gen, put drill in forward if reversible, start gen, then turn drill chuck backwards. This should excite the field.
Note.: It says be careful you don't get your hand caught in the chuck when the gen gets power and the drill starts spinning forward.
Old 07-20-12, 05:15 PM
cheese's Avatar
Received 120 Upvotes on 110 Posts
10 volts is much more than needed to return the field to full polarity. I think something else is wrong.
