NM
07-24-12, 03:16 PM
6.75 hp Husquarna carburetor problem
I recently "inherited" a Snapper lawnmower that hadn't been started in three years. The label on the cowling says "6.75 hp Husquarna Crown Series", but the cowling has "Briggs and Stratton" stamped everywhere else, including the model #, which is 1901VE 275078. I know the engine is not the original.
I took the carburetor bowl off and cleaned it, sprayed cleaner through the intake, and put carburetor cleaner in the gas. Checked out the float (works fine). Finally got the engine to run. It runs great, but is a pain to start. It cranks over on the first pull, but then I have to push the primer bulb for about two minutes to keep it running. After the two minutes with the process, it runs great. I can even stop to change the bag and it starts right back up and runs great. I've sprayed cleaner through the carb. while it is running. What do I need to do to eliminate the first two minute primer bulb issue?
GA
GA
07-25-12, 09:59 AM
Yes, but using a wire doesn't necessarily clean the hole all the way to the full diameter of the hole. The wire is almost definitely too small to effectively clean the entire diameter. Thousandths of an inch make a difference when talking about jet size.
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
