Poulan chain saw won't start
Received 0 Votes
I have a 42 cc poulan that i just can't get to start. It has brand new gas, i've removed the spark plug and it is sparking very well. But if i put the plug back in it just won't fire. If i dump in a shot of gas or ether right in the cylinder, it doesn't even pop.
Its acting like when i stick the plug back in the cylinder, it isn't sparking, because i've pulled the plug out and sometimes its wet, and if i crank it over it'll burn off it i off. Any ideas? I'm maybe thinking something like piston rings? At this point i have the air filter out.
Thanks
Thanks
Is this saw new to you so this is your first time trying to start it? Or, did it run fine last season and this is the first time trying to star it in months?
When a saw won't start with the normal starting procedure I try having the choke off and hold the throttle wide open and give it several good pulls which sometimes helps if it was flooded.
I had to change fuel lines in 3 saws this year, due to age. It happens. Of course if you are getting a wet plug, that may not be the case. My 4th saw was a Poulan 3400 Countervibe bow saw. Forget the fuel line replacement and take it to a repair shop. I had it torn down way too much and decided I couldn't change the lines.
Received 0 Votes
well this started when i first broke out the saw this summer from sitting all winter. It did run fine last year. It never fired or anything from the moment i tried this year, maybe its flooding every time i try it. I would think after pulling on it a million times it would clear out. I don't have a compression gauge but if i cover the spark plug hole with my finger, it does push and pull air.
