Briggs and Stratton 20Hp runs great without the air filters in place - not dirty
Received 0 Votes
Briggs and Stratton 20Hp on craftsman lawn tractor runs great without the air filters in place and they don't seem to be dirty. It dies when the filters are in place and at high rpm's. Cleaned carb, changed oil, filter and plug.
Also, choke not opening when lever is released! New to all of this and wanting to learn. Thanks in advance to any good ideas.
Received 0 Votes
Fix the choke issue first,,,you may have dirt in the carburetor where the choke shaft rides, some times dirt build up in the hole where choke shaft mounts in carburetor. Make sure also you change out the Pra filter or clean it really good, also if you cleaned the air filter I have found sometimes all the soap used to clean it doesn't get all washed out and it will cause the carb to choke down, also make sure it is good and dry, but with that choke sticking it will continue to run sick untill it is fixed first. If choke is off have you tried a NEW air filter. Anyway that's my two cents worth,,good luck.
