Murray Riding Mower-Peerless Transmission 930-032 shifter frozen
Received 0 Votes
Shifter in my Murray riding mower is frozen. I can force it into R and 1st gear, but nothing else. I suspect the gears inside are rusted as the mower was under a tarp that leaked!
I've found a diagram of the Peerless/Tecumseh 930.032 tran but it doesn't show me where all the bolts are that hold the darn thing up under the tractor and w zero clearance underneath I can't inspect it properly.
Any help?
Also, is it OK to tip the mower onto it's backside-tailend to work on it?
Thanks a million! My grass is knee high........
Any help?
spray some PBlaster at the point where the shifter enters the top of the tranny and work it back and forth, spray more, repeat, until it shifts normally. There are needle bearings in this area that tend to get rusty, especially if the mower sits outside and grass accumulates on top of the tranny. If this doesn't do it, you'll probably have to remove and disassemble the tranny. It's not advised to flip the mower. You'll need to raise the back end, remove the rear wheels, then the tranny will drop down easily.
