snowblower runs 30 seconds then dies
hi i have a very old hahn eclipse snow blower with a 4 stroke briggs and stratton engine that runs for about thirty seconds then it dies it only runs on full choke and i just put a new fuel filter on(before that it wouldnt run at all) i can see into the fuel filter when it dies and there is no fuel do i need a new fuel cap??
It could the cap. Just loosen it to see if that fixes. If not you still have a fuel delivery problem that could be a restriction in a line or a plugged outlet at the gas tank..... that sort of thing
The running/dieing like yours is 99 percent of the time fuel delivery to the engine.
Your main jet is dirty. Very simple fix. The main jet is a bolt on the bottom of the bowl. Reminder taking the bolt out will that the bowl off so hold onto it. After taking the main jet out simply run carb cleaner through all the little holes in it make sure its nice and clean and it should run great!!
