nikki carb prolems briggs & stratton motor 18ohv
Old 09-01-12, 10:44 AM
B
please help i have rebuilt carb with new kit new gas new filter and new plug now wont start just turns over but wont start carb bowl has electronic plunger on bottom is this the problem seems like not getting fuel
Old 09-01-12, 12:27 PM
Tolyn Ironhand's Avatar
Received 710 Upvotes on 603 Posts
Did you check for spark? Did you check the gap on the plug? Have you tried any starting fluid to see if it will pop off? Is the gas on? Is there gas in the carb?
Old 09-02-12, 08:28 AM
B
yes i have checked all of the above good news is i figured out the problem needle valve in wrong i did not have it under the fork so it was not letting fuel in thanks for your help it runs great now
