Craftsman mower honda motor wont start
Old 09-03-12, 07:22 AM
G
My Craftsman 917.378551 with 5.5 Honda OHC motor 260778 S3A won't start
Was running OK then just conked out. I have spark, new air cleaner, replaced the spark plug, changed oil and gas. Removed dis-assembled and cleaned carburetor with carburetor cleaner, checked magneto gap (0.010). All the linkage looks good, carb fuel bowl is getting running supply of fuel. removed plug with finger on the spark plug hole I have compression (though not measured with guage) Will run for a moment if I spray starting fluid into the carb. Any suggestions.
Old 09-03-12, 10:13 AM
cheese's Avatar
Received 122 Upvotes on 112 Posts
If it will run with starting fluid, then it's not getting gas from the carb. Something got clogged in it.
Old 09-03-12, 11:49 AM
G
If its runs with starting fluid or carb cleaner that means the problem run with your carb. I would try a carb kit. With a pic i could tell you more. Otherwise i hope it all works out!!!
