Help [Replace Beelts - huskee mower]
The belt to the blades is easily replaced but the others are not. If you aren't pretty good at mechanical repairs, this might be best left to a pro who knows what to do and how they are changed. If you have confidence in your abilities and want to do it yourself, we can help. The engine pulley has to come off, the transmission pulley will likely have to come off, and the deck should be removed (to give an idea of what you're going to have to do).
the deck is off I have 2 of the belts on cant figure out how to put the 3rd one on. I have the drive belt and the belt to blades on. do you know how to put the 3rd one on? thanks for your help.
Which one? There are 2 drive belts, one from the engine to the variator, and one from the variator to the transmission.
