murray riding mower - how does grass catcher attach at deck
I have a murray 14.5 hp 42" cut riding mower with what I think is a 24744ma bagger attached. The only problem is, I believe I am missing whatever holds the tube extension to the cutting deck. Also, what do you do with the grass diverter that is attached to the deck if you are using the grass bagger?
You just lift the deflector chute out of the way to put the catcher tube on. I believe it is held on with carriage bolts and wing nuts if I recall correctly.
