unloader and bull whip. Howzzat work?
hoary's Avatar
AL
09-29-12, 10:10 PM   #1
I have a tank and a B&S engine. Planning on making a 'cost reduced' air compressor.
I've had the engine working, compressor works too.
Now I need some way to bring the B&S back to idle when the tank is full.
95-150 Lbs for the tank and compressor.
I'm having trouble 'inventing' an unloader that will bring the B&S to full throttle when the Tank pressure is down to 80# or so.
And when the tank is full enough for the Pop-off valve to open, the throttle on the B&S will drop back to an idle.
I'd sure like a diagram or explanation of the Commercial UN-loaders and the bull whip that handles the throttle on the B&S.
cheese's Avatar
GA
09-29-12, 10:41 PM   #2
Some have a valve that unloads and pushes a throttle cable to control the throttle, and some have a small hose that runs from the unloader to a air-operated piston that controls the throttle. The unloader pops at the set tank pressure and it unloads the valves in the head, letting the valves in the head move a piston that either moves the throttle cable or is piped to the throttle itself where the piston moves the throttle directly.
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
31YTech's Avatar
FL
09-30-12, 02:10 PM   #3
Hello hoary,
Here's a short clip on pilot unloaders
Also one on bullwhips
You may be able to get by with just a pilot valve such as THIS with a Bullwhip instead of a full on unloader valve, But I've never tried this.
Good Luck to You !
