Briggs & Stratton 18hp v-twin
Replaced one of the coils on the engine. I am getting spark at the plug but that side is still not working. Any ideas?
Thanks
Thanks
Hello drew3267,
Remove the valve cover on the offending side and check the valves/rockers and pushrods, A pushrod could have popped out from under the rocker or gotten bent from a hung valve.
Engine model-type and code numbers posted would be helpful in going further.....
Good Luck
Good Luck
drew3267,
Since you found the top "arm" (= rocker arm) loose, It's possible the piston wasn't at TDC (= top dead center) compression stroke or it's out of adjustment. But none the less if you have spark I think you need to make sure the valves are at the correct setting, Follow the diagram below;
There's one other thing I'm thinking but since the valve cover is off it's best to eliminate the valves first at zero cost......
Ding...Ding...Ding....We have a winner. I finally got a break to work on the mower and when I went to adjust the rocker arms and found out the lower pushrod had popped out.
Is there anything I should check before trying to reinstall? Or do I just need to make sure they are not bent?
Thanks!!!
Thanks!!!
drew3267,
When you re-installed the push rod you went ahead and checked/adjusted the valves as outlined correct ?
If so, Remove the top cover (flywheel cover) again. Disconnect the small black kill wire from both coils, Set the cover back on with just a couple screws to hold it in place. Start the engine and see if this faulty cylinder now runs, If your carb has a fuel cut-off solenoid on the float bowl the engine will still shut off with the key switch but will run a few seconds after turning the key off before shutting down.
If your carb doesn't have this fuel cut-off solenoid, Loosen the spark plug wires on the spark plugs so they can easily be removed by popping them off with a screwdriver.
Should the engine run as normal with the kill leads disconnected from the coils, There's a faulty diode in that kill lead harness that's causing a feedback making that cylinder skip even though you have spark. There's no substitute for this kill lead harness so you'll need to pick up part# 692319 from your local repair parts dealer.
Good Luck
Good Luck
