Lawn Mower Can't Start
Hi, don't know which forum should put for my question.
My lawn Mower can't start now because of not using for 2 weeks. I pumped the fuel on the soft rubber button many times but still not start. I have found the gas was leaking to air filter side when I pump the fuel. May the gas can't reach to the engine? The spark plug is ok. Please tell me what's wrong with it and how to fix if anybody knows it. thanks. Rick
Hi Ikl818,
If you post what lawn mower you have, others here will be able to help you better.
In the mean time, try to remove the spark plug and pull the engine through several times to clear the cylinder. Remove the air filter. Wipe or blow off the spark plug and re install. With out priming, (not pushing the soft rubber ball) try to start (with the air filter removed). If no start, give the ball one or two push then try again.
Thanks for reply. Actually I had done the way you said, not help. My concern is why gas is flow over to the air filter side when I was pushing the soft rubber ball.
Most likely when you prime too much... (the soft ball is a primer) should only need 3x push, if you push too much and soak the air filter with fuel, it will not let the engine breathe and will not start.
I agree. The primer pushes fuel into the carb. It can run towards the air filter or not, it doesn't matter. If you push it too much, you flood it. Have you checked for spark?
Thanks All.
I have re-tried the procedures and pushed 3 times of soft ball so that it is started. It's great. It looks like I pushed too much fuel to the Carb. at the beginning. The model is MTD Yard Machine, 5HP. Thanks anyway.
