murray belt installation
I have a murray wide body 42" cut. Part of the model # is gone. I can only make out 425 as the first numbers. It has two drive belts a primary belt #37x112 and a secondary belt 37x113. My problem is I need a diagram on how to install the belts. Thanks.
smenguy,
From what I see only three machines used a 425 leading number, 425303X92A year 2002, 425303X92B year 2003 and 425307X51A year 2008..... If this machine has the original engine and is a Briggs, The first two digits of the engine CODE number denotes year of manufacture......
Good Luck
Good Luck
