Coleman Powermate 5000 Generator won't start
Old 10-29-12, 11:30 AM
W
I have a Coleman Powermate 5000 that I purchased in 2001.
It won't start.
The rope turns the flywheel and I get a backfire.
It has fresh gas, which is making it to the carb, a new spark plug, cleaned carburator.
What am I missing or doing wrong?
Old 10-29-12, 12:18 PM
P
Received 1,849 Upvotes on 1,655 Posts
You did not say how you cleaned the carburetor. If you did not remove it from the engine and disassemble it, I would do so. Just spraying cleaner at it or down the throat will not do much. You have to clean all the tiny orifices, passages and jets.
Old 10-29-12, 12:24 PM
W
I removed the carb and cleaned the entire thing.
Old 10-29-12, 12:41 PM
N
Received 20 Upvotes on 18 Posts
Try removing the plug, adding a tiny bit of gas in the cylender head and replace the plug. Should fire and hopefully draw the fuel from the carb.
I think these have a fuel shut off, is it open? I own the exact same model, but can't remember if it has a shutoff.
Old 10-30-12, 06:54 AM
W
It does have a fuel shutoff but it is open. I checked the flow when I pulled the carb.
I pulled the plug and added gas with the same result, no start.
The strange thing is that it backfires.
So, it looks like it's getting fuel and a spark.
Old 10-30-12, 10:24 AM
cheese's Avatar
Received 122 Upvotes on 112 Posts
Does the engine have compression? The backfire indicates a valve open at the time of firing. Could be a stuck valve or an ignition timing problem (possibly flywheel key).
Old 10-31-12, 08:36 PM
I
Received 1 Upvote on 1 Post
I had one of those, does it have the Subaru/Robin engine?
If so, the valvetrain is chain driven and very easy to access. Pull the valve cover and observe the timing marks.
I am with the big Cheese on this one....could you have sprayed into the intake and knocked a piece of crud under a valve?
Backfire is either from the intake valve stuck open or timing is off......both holding the valve open slightly.
Page 23 shows the timing....providing you have the Subaru/Robin engine.
http://www.robinamerica.com/media/ma...3120321250.pdf
