Tecumseh 12hp starter Problem with Magnets
Old 11-08-12, 11:12 AM
R
have starter motor 33605 on tecmseh 12hp. One of the four magnetic came off inside. What do I use to glue it back in Regular Epoxy or JP weld epoxy or is there something else to use? Has anyone done this?
Old 11-08-12, 11:38 AM
R
What happens if I only use 3 of the 4 magnets in the starter ?
Old 11-08-12, 06:36 PM
cheese's Avatar
Received 141 Upvotes on 130 Posts
The starter won't have the power it should, probably not enough to even work and may burn up the windings. Epoxy or JB weld would work. Make sure not to flip it over the wrong way with the poles reversed.
Old 11-09-12, 05:16 AM
R
Thanks, I have cleaned and JP Welded it. Let it sit overnight and put it together.
Will try it today
Old 11-09-12, 11:31 AM
R
Well I put it all together and now I have sparks flying out the strater!!!! what did I do wrong????
