Hi lo carb settings 25cc craftrsman leafblower
Old 11-18-12, 09:28 PM
L
Angry Hi lo carb settings 25cc craftrsman leafblower
I have an older craftsman 200mph leafblower model#358797550 .The plastic stops are gone on the hi lo screws and i cant get them adjusted close enough to start .how many turns out (roughly ) do they need to be turned?? anybody THANXX
Old 11-19-12, 05:45 AM
Many will have different answers to your question. I have had good luck with about 1 1/4 turns on each. Good luck
Old 11-19-12, 09:49 AM
G
Received 28 Upvotes on 27 Posts
The carb sites have good info about adjusting their carbs, Welcome to USA Zama or Walbro We Enable Machines that make life better! on either site select the Service/Aftermarket tab. Before you get too frustrated with it not starting try moving the cylinder, those blowers have a tendency for the cylinder bolts to come loose and create an air leak, second remove the muffler and check the piston and cylinder walls, if you see deep scratches the blower is shot. Also you need at least 90lb compression for it to run. Have a good one. Geo
