Whacky (Erratic) voltage (Portable Generator)
I have a "gimme" Honda EX1000 generator which runs flawlessly. I noted the engine speed was a little higher than normal, but didn't think too much of it. I tested it by plugging a trouble light into it. After the welding type flash left my eyes, I tested the 120v receptacle. Across hot and neutral I was getting 265 volts. Hot to ground 130+ and Neutral to ground 130+. I spooled the speed back keeping my meter plugged into the receptacle until it dropped to 126v or so. Does the engine speed have that much to do with what I get across the receptacle contacts?? Is it possible the generator is faulty?
Toolmon, it seems to settle down to hot and neutral with the slowing of the engine. That's why I was wondering if over revving the engine would cause a sine wave malfunction in the generator itself.
Brant, how true, especially on the Fein.....ouch! My baby!!
Thanks guys. I'll start checking for misplaced wiring etc. Just wanted to confirm it was abnormal. Too nice a generator (although small) to just throw away. I may can use it like Justin does, and have a party!! Heck, they want $350 on Ebay for them
It was free, so I can afford a little time.
How did you throttle the speed down? All the small generators I have seen run at only one speed which is correct for the output voltage. You may have a bad governor.
What was the voltage between neutral to ground when it was at normal output voltage?
Free is awesome!
Free is awesome!
Received 5 Votes
Larry
My Two Cents...
Engine speed is very important! Highly Critical aspect. Has a lot to due with voltage output. That free be you got might have been tampered with by previous owner. May have attempted to gain more voltage by tampering with engine governor speed control or device. Very bad idea to over speed any small engine.
Best suggestion (IMO) for a first time attempt to fix or diagnose possible problems is to check engine RPM's. Use a small engine tachometer. Engine speed not to exceed 3600 hundred RPM's. Any speed above that will cause internal engine damage! Like stretching the piston rod and or floating any over head valves engine may have.
And there you have it..."My Two Cents"...
Regards & Good Luck. Sharp Advice.
25+ year Vocational Small Engine Tech. Web Site Host, Forums Monitor and Multiple Topics Moderator.
My Two Cents...
Thanks, Tom and others. I just wanted confirmation. Once I spooled it down via the governor adjustment screw it reverted to normal 120 volt operation. Scott, the Neutral to ground in 120 volt operation also went to zero. Yes, the governor spring had been modified somewhat, so I will seek a new one and replace it. I think he was thinking more RPMs meant he could get more wattage. It's a small "light bulb string" generator, not meant for motors or other items over 8 amps or so. It's cool for it's purpose.
Thanks, again guys.
Thanks, again guys.
Not sure if you have the service info on that piece but Honda has pretty good manuals. The wiring diagram is on page 36
http://powerequipment.honda.com/pdf/...s/31ZC0020.pdf
