Portable gas generator
I'm researching portable gas generators,and came across a Generac Model GP6500 E that i like.
Hoping the portable generator folks here will chime in with
good/bad comments. Thanks
daswede
daswede
Here is the spec sheet..... Why do you like this one?
http://www.generac.com/SpecSheets/01...6500E_5941.pdf
If it were myself I would prefer a unit with a 120/240 ---120 only outlets so you can use both windings at max amps at 120v. Has selector switch.
They only have two that do that.
xp 4000
http://www.generac.com/SpecSheets/0196510SBY_XP4000.pdf
xp 6500E
http://www.generac.com/SpecSheets/01...BY_XP6500E.pdf
The other two larger in the xp series dont have the switch but I assume the 120v only outlet is hard wired using both windings.
You have 240 loads?
xp 4000
xp 6500E
You have 240 loads?
Received 0 Votes
It would be helpful if you can post how you're going to use this.
Is this for backup power to your home? If so, are you going to use extension cords to power a few lights and appliances, or are you going to have it connected via an interlock kit or via a transfer switch to give you broader power use in your home during an outage?
Or are you buying this for portable power?
Or both?
The more specifics you can provide, including what circuits, appliances or equipment you intend to power with it, the better. Some generators are great for one purpose, and terrible for another,and vice versa.
Or both?
Thanks placekicker, and lawrosa for your replies.
This model was recommended by electrician i contacted. The generator would be wired in with a manual 10 circuit transfer switch,30 amp power outlet box,and 25' 30 amp. cord.
This Generac GP6500E has one 120/240 outlet,and four 120 outlets.
This generator would be for back up in power outages.
I don't plan on using any 240.
I would want to power the refrigerate, small dorm refrigerator,small microwave,large TV, 4-5 lamps of 60-100 watts,small radio.
no pumps,electric stoves,or water heater
I guess i would be limited to the transfer switches. Any suggestions would be appreciated
Update:
I contacted a local installer, and got a quote.
Install a Generac GP6500E,assembled and tested .supply and install a 10 circuit manual transfer switch. Supply and install a 30 Amp power outlet box out.
Supply a 25' 30 amp cord. parts and labor `$2100.
Comments please
Comments please
From my calculations the gen is at least 1K. The switch and such is at least $500.
6 hours at $100 an hour.... $2100...
Get a permit and its a great deal IMO.
But I dont think you need a gen that big. I am infactuated with 120 only gens.
He is a licensed Heating installer heat.
I thought it was a pretty good price to,but wanted to run it by you "experts".
My next concern is some type of housing over the unit. Here in the snowy/rainy
Northeast is a big concern for equipment to be outside.
Received 0 Votes
Keeping your generator dry is important. They're not designed to get rained or snowed on or ice-stormed on. There's a good chance that when the power goes out, the weather will be miserable. It's also nice to have your generator installed in a permanent place, assuming you don't live in a place where it's likely to get stolen. Wheeling it out during a storm in the dark is a pain (power failures always seem to start in the dark for me).
I built a 5' by 5' by 5' enclosure (see this post, comment #19):
http://www.doityourself.com/forum/ou...ator-rain.html
I've added additional vents since the pictures were taken.
It was a lot more work than I thought it would be, however. You could buy a utility shed and add ventilation or buy some other type of enclosure. Bear in mind that the generator you're buying is air cooled and also needs fresh air to run, so if you go with a utility shed, you'll be best off running it with the doors open and fans to blow the exhaust out the vent, or some type of hose that will vent the exhaust directly from the exhaust pipe outside of the shed.
If you want to go with something temporary, for most storms, a 4 by 8 sheet of plywood suspended on sawhorses or cinder blocks will keep it dry. That way it will get plenty of air. Just make sure it is locked, because these things do get stolen during long outages.
