cub cadet LTX1040 wont start.
Old 12-01-12, 08:34 AM
B
I changed the battery but now there is NO power. It wont start, dash does not light up. Tried jumping it off at the starter but it only spins and spins but will not turn over (and still dash does not light up/no power getting to it. Im thinking the spark plug and/or the fuses. Spark plug I got. Fuses I cant locate. Where is the fuse/fuses located?
Thanks!
Old 12-01-12, 10:25 AM
cheese's Avatar
Received 97 Votes on 90 Posts
Jumping it to the starter won't let it start. The fuse can be a lot of places on mowers. Usually there is a small red wire coming from the battery cable side of the solenoid and if you follow it back, you'll find the fuse in that wire.
Old 12-01-12, 10:35 AM
Received 2,983 Votes on 2,690 Posts
Looks to be a 20 amp fuse. Connects between red wire on starter solenoid and red/white to term B on ignition switch
Old 12-02-12, 10:45 AM
B
Found it. Changed the fuse, changed the spark plug Now I got power but the mower still wont start. It continues to spin but wont turn over. New battery has plenty amps. This mower is only two yrs old and only used during spring/summer months. Has the engine locked up somehow?
Old 12-02-12, 10:55 AM
Did you check for spark ?
Old 12-02-12, 02:12 PM
Halton's Avatar
Or the gap of the new plug?
Put the old spark plug back in and see if it starts now that you fixed the fuse.
Old 12-02-12, 10:23 PM
cheese's Avatar
You say it spins, but won't turn over and mention it might be locked up. That doesn't make sense. Spinning and turning over is the same thing. If it's locked up, it won't move at all. Is it turning over, but not starting, or is it not even turning over? with the blown fuse and the jumping stuff, I am thinking that you probably reversed polarity to the system which may very well have burned up your coils and possibly the charging system. Do you have spark (if it's turning over to check it)?
Old 12-03-12, 10:11 AM
Well said Cheese. It has to be doing one or the other?
