kohler cv20s camshaft removal: help please
Old 12-07-12, 08:27 AM
My camshaft is broken in the middle; the gear side fell out with no problem. The other end rotates in the bearing bore but is resisting serious persuasion with a side hammer. I see no reason for resistance, I find no comments in the manual. Has anyone else had a similar problem? I worry that more force may crack the block but I'm running out of options. Please advise.
Old 12-07-12, 02:25 PM
Have you taken out the lifters? Take valve covers off and loosen rocker arms so push rods come out, then remover lifters also post Model and Spec number.
Good Luck.
Old 12-09-12, 04:02 PM
yeah done that
thanx mowerdude i appreciate the input the lobe half of the camshaft is the last thing to come out of this block...and a small slide hammer seems inadequate so far. any recommendations on explosives?...just kiddin..seriously though, i want this piece outa my block...HELP!
Old 12-09-12, 06:47 PM
cheese's Avatar
If it's in there that bad, you may have a bad boss in the block anyway and it might ruin it the rest of the way getting it out. I have never run into that scenario before. I have seen crankshafts that didn't want to come out because of scoring. This may be the case here too.
