Troy-Bilt 2550 Pressure Washer Oil Drain Plug?
Old 12-11-12, 03:03 PM
Hello,
I have a Troy-Bilt 2550 pressure washer that needs to have the oil changed. The engine is a Briggs & Stratton 675, 190cc. With my mowers, I usually just unscrew the drain plug from the bottom but this has what I'm assuming is the water pump attached and is in the way. There is no side drain plug either.
Am I missing something here or is this common? The only other option I can think of is to drain the fuel and empty the oil by turning the whole thing on it's side.
Any advice would be appreciated.
Thanks!
Old 12-11-12, 03:47 PM
cheese's Avatar
Received 122 Upvotes on 112 Posts
You got it, dump the oil from the fill tube.
Old 12-12-12, 04:01 AM
Received 757 Upvotes on 662 Posts
Is this becoming the new norm? We bought a new murray mower this year and when I went to change the oil I couldn't find the plug. Even double checked the owner's manual only to find that you must turn the mower upside down
Old 12-12-12, 07:23 PM
cheese's Avatar
I don't know if it's the new norm or not, I use a vacuum tank to change the oil through a tube that sucks it out of the fill tube, so I rarely bother to open a drain plug.
