Need A Little Help
Old 12-19-12, 03:10 PM
Need A Little Help
I am working on a Honda Generator,,ES6500. Customer brought it to me as a non running machine but had already sent Carburetor off to be fix by someone in WI. Oh the numbers off the engine are GA01-1301-223. Well I found the problem why it would not start, fuel solenoid froze up from bad fuel. I got the solenoid working and it does run but runs poorly. Surges and when placing it under load (working a drill) it will run rich, spit black smoke. Took it apart again found a split o-ring on float bowl nut. Put it back together and it does the same thing. Took it apart again and let it sit for 8 hrs in cleaner and still runs poorly, rich, surging. Iam lost for what is wrong. New carb is $126.00,,but I didn't leave the fuel in it to ruin the carburetor!! Any Ideas???
Old 12-19-12, 05:00 PM
cheese's Avatar
Received 120 Upvotes on 110 Posts
Look at part #43 on this site. Most honda carburetor problems are found in this part. Either the jet gets clogged or someone reams the hole out, making it too big, or messes up the o-ring.
Honda GX360K1 Parts List and Diagram - (Type ES23)(VIN# GA01-1100001-1399999) : eReplacementParts.com
Old 12-19-12, 05:29 PM
I checked that out today Cheese and the hole is open but I did not replace the o-ring and I will check it closer, thanks
Old 12-20-12, 11:22 AM
Well Cheese I didn't see anthing wrong with part# 43 but I broke the top off it trying to get it out so new one in on order,,just my luck with this thing!!! Broke the end off the air mixture screw yesterday,,,,I am starting to feel like a butcher, everthing I touch on this thing breaks!! so I shoved it to a corner I cannot see,,Haaaaaaaaaaaaa
Old 12-20-12, 03:14 PM
cheese's Avatar
Yeah, the mixture screw in made to break if you try to tamper with it and get it out. I'd be tempted to just buy one of the chinese knockoff carbs for $30.
Old 12-20-12, 08:55 PM
I have ordered replacement parts already so we'll see where this goes, I'll let you all know what happens.
Old 01-03-13, 02:28 PM
Honda up and running, found another split o-ring. But this machine has a propane conversion kit on it and with propane orfice installed it will spit black smoke and run really rich under load, took out orifice and will run like a champ,,customer to pick up in morning! Thanks for help cheese.
