mtd snowblower problem
Old 12-27-12, 05:33 PM
G
my snowblower auhen it stoger turns until you put a load on it then it stops
Old 12-27-12, 05:41 PM
Received 3,485 Upvotes on 3,128 Posts
Excuse me
There may be a belt or clutch disc slipping.
Does the fan part (blower) also slow down and stop ?
(Requires a second person to verify)
Old 12-27-12, 05:56 PM
G
is the fan part the auger? if so yes took the belt cover off also belt stops also drive pulley
Old 12-27-12, 06:04 PM
The fan/blower is belt driven and then at the end of the shaft is a gearbox that drives the auger.
It's not uncommon for the gearboxes to get chewed up.
Old 12-27-12, 06:10 PM
G
both pulleys and belt everything stops its like it has no power its a 2007
Old 12-27-12, 06:21 PM
There is a drive pulley that spins with the engine and there is a second pulley that is connected to the blower/fan shaft.
Usually the belt just slips on the pulleys until you pull the handle.
There should be an adjustment on the bottom of the linkage.
The adjustment should be two nuts tightened against each other on the threaded linkage.
If you look at the action of the handle you should see the adjustment moving with the linkage.
Above all......practice safe snowblower repairing. Do not put your hands in where the belts and pulleys are spinning.
Old 12-27-12, 06:40 PM
G
it has 2 pulleys and one that presses the belt down when you pull the handle the belt shuld be tight right? it seems to have slack in it still dont really see an ajustment
Old 12-29-12, 06:35 PM
G
hey,PJmax... it was the belt thanks for the help Glenn
Old 12-29-12, 07:23 PM
Good news Glenn
