Auger doesn't turn
Received 0 Votes
Auger doesn't turn
My ariens model 924028 snow blower augers aren't spinning. The blower in the housing is spinning but not the augers. Both shear pins are fine that was the first thing i checked. I found one post about an MTD blower with this problem and was wondering if that would be the same fix for mine. The auger spins freely by hand and you can see that the shaft it is attached to is alsoo spinning with the auger.
The augers should not spin freely.
I'm afraid you have issues with the gearbox.
It would be a similar fix. You'll need to remove the auger and blower/fan unit.
Received 0 Votes
augers spin freely
did you have a look to see if the sheer bolts broke off. If these bolts came off, one or both augers can spin freely. This is a safety mechanism to protect the gear box from being ground to a pulp should you hit something.
Unfortunately just from use the gearboxes get ground to a pulp. There is a LOT of torque on them.
Last time I rebuilt mine I installed a Zerk fitting and now keep it full of synthetic grease.
