Oil drain extension cap problems...Crarftsman snowblower
911jeep's Avatar
CANADA
02-05-13, 02:50 PM   #1
So...figured I'd give my Craftsman snowblower it's first oil change.
Removed left side tire per owners manual. Put a wrench on the oil drain cap and the whole extension is spinning where it's tapped into the base of the engine block. Tried securing the nipple with some good pliers but no luck.
I certainly could drain the oil by removing the nipple but what a freaking mess I would have.
Any ideas on how to fix this would be great.
I'm gonna head off to the Sear's outlet where I bought this thing to vent some frustration.
Thanks for any help.
So...
marksr's Avatar
TN
02-05-13, 03:04 PM   #2
How so? was the pliers slipping? maybe try a pipe wrench to hold the extension.
retired painter/contractor avid DIYer
cheese's Avatar
GA
02-05-13, 04:28 PM   #3
Yup, pipe wrench or maybe some vise grips.
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
sidny's Avatar
NY
02-06-13, 06:05 AM   #4
The craftsmsn
And when you do get the cap off, or even before, tighten that pipe nipple into the motor base good enough so when you take the cap off the next time, the pipe will stay put.
Sid
daswede's Avatar
MA
02-06-13, 10:27 AM   #5
Had the same problem with drain on my Ariens. Solution was to replace
the cap with a pipe thread Ball valve.
And,yes,i had oil all over the place to when i removed the pipe.
mla2ofus's Avatar
TX
02-06-13, 08:56 PM   #6
And if you install the valve, lightly tighten a pipe plug in the valve.
Mike
marksr's Avatar
TN
02-07-13, 04:25 AM   #7
Ya, I was wondering about the accidentally being opened Removing the handle might also work but a cap would be better.
911jeep's Avatar
CANADA
02-07-13, 12:00 PM   #8
Thanks for all the input fellas. Oil change is done.
Could not get a good bite on the nipple with a small pipe wrench.
What did work was the vise grips. Oddly, I'm not much of a vise grip guy but I am now.
Thanks again for the replies!
thank
