Snowblower Toro 521 will not go into drive
Old 02-14-13, 06:53 AM
I have a Toro 521 Snowblower, Model 38052, Serial 9017024.
The machine will not go into drive and I'm looking for advice.
The machine otherwise runs like a champ.
I'm hoping there are some simple things I can do/check prior to something more major.
Old 02-14-13, 10:35 PM
Good machine. I have one from the 80's. Still going strong.
The selector wont go into drive or it does but the machine just doesn't move ?
Old 12-28-13, 11:24 AM
The self propel does not work when handle lever is engaged. Belt is on and in decent shape
Old 12-28-13, 11:39 AM
Did you remove the rear cover. It uses a friction plate drive system.
See if the drive is engaging the plate when the handle is pulled.
Part 36 is the drive plate.
Parts and Diagrams for Toro Consumer 38052, 521 Snowthrower
Old 12-28-13, 11:40 AM
.......and machine won't move.
Old 12-28-13, 11:54 AM
I did remove the cover and the friction plate does engage and the wheels move. But if I hold the machine back slightly the wheels stop and so does the traction belt. The belt also seems to be a bit loose. Do I need to replace the traction belt 37-9090?
Old 12-28-13, 12:05 PM
PJ, just curious if you're still out there?
Old 12-28-13, 03:38 PM
I'm here Dan.
You may have a stretched belt.
The drive is also adjustable where the arm comes out the rear by the plate.
I've only changed the belts twice in all the years I've had it.
Old 12-28-13, 03:54 PM
I know nothing about this product, however some things are universal,with that said, maybe the pulley is worn, check the that the belt is fitting in the pulley and not bottoming out, if the bottom of the pulley wedge is shiny then the belt is not making proper contact. Have a good one. Geo
Old 12-29-13, 07:51 AM
I'm guessing at a minimum the belt is stretched/loose. I did tighten up the adjustment on the lever arm to maximize contact with the friction wheel and plate.
Does anyone know of any belt replacement videos to view?
