Toro Tiller engine replacement help
Old 02-16-13, 03:22 PM
G
I recently bought a 1975 Toro 3hp Rototiller which has a bad engine. I'm looking to replace the engine with something similar but wondering if I will have a hard time finding the right fitting engine.
The motor on it did have a reverse shaft as seen in the picture below. I heard I can still use the tiller without a reverse pulley.
Are most small engines pretty universal in their dimension from the mounting plate to the output shaft location?
Engine: Tecumseh H35-45437k
Tiller model: 58015
Name:  Picture 016 (1000 x 750) (750 x 562).jpg
Old 02-16-13, 09:50 PM
cheese's Avatar
Received 122 Upvotes on 112 Posts
Some like size engines have similar mounting patterns and crankshafts, but not all. Measuring is the best way to know what will work.
