14 horse briggs vanguard twin will start and run until it gets warmed up
Old 04-01-13, 05:32 PM
just like the title says it will start and run for about 10 minutes but will just shut down once it gets warmed up no sputtering, not starving for fuel just shuts down like the key is turned off any suggestions?
Old 04-01-13, 09:33 PM
Please make sure fuel vent is open. If it is not open the fuel will not flow.
Old 04-01-13, 11:13 PM
cheese's Avatar
Does it start back up? Does it have spark?
Old 04-02-13, 05:30 AM
Certainly try what mowerdude recommended by loosening the gas cap. If it still dies after getting good and hot I suspect a bad coil which is the spark that Cheese was asking about. They (coils) can be annoying because they often start working again after they have cooled down so you have to check for the spark right away while it's hot.
Old 04-08-13, 05:50 PM
When the engine stops, before you do anything else open the fuel tank cap and listen for suction of air. This will tell you if the fuel vent is open. Pilot is correct as far as the coil, have a spare spark plug ready when the engine dies. Pull the plug wire off, put the spare plug into the wire, hold against engine frame and turn the engine over to see if you have spark.
Trackbacks are On
Pingbacks are On
Refbacks are On
