Help locating spring location on Briggs and Stratton engine (for lawnmower)...
Old 04-05-13, 05:30 PM
H
Well, I was getting the old push mower ready for the new season and though I was grabbing some loose twigs behind the air cleaner and ended up pulling a spring out
From what Briggs and Stratton is telling me, the part# is 790849 and it's called a
Spring-Air Vane. My only problem now is figuring out where the heck I pulled it from. Here are two pics of the engine. You can see one spring in place. The other came from the same area. Any help would be appreciated.
Lawnmower Photos by buckrogers21st | Photobucket
Thanks, Andy
Old 04-05-13, 05:56 PM
XSleeper's Avatar
Received 1,844 Upvotes on 1,659 Posts
All I see is dirt. LOL
If memory serves, the air vane has a spring that connects it to the governor. You probably need to remove the shroud over the flywheel to see where the air vane is.
You should be able to google your B&S model # and get a decent image of the spring location. Or you could tell us your model number and we could find it for you.
Maybe this pic will help?
Old 04-05-13, 06:33 PM
H
XSleeper, I think you might be on to something. I posted two additional pics at the same URL. I do have a parts list with exploded diagrams, but I can't seem to find that spring in their drawings. The model# is
126T02
Do you think the area I have highlighted is where it goes?
Thanks,
ANdy
Old 04-05-13, 06:38 PM
31YTech's Avatar
I agree with XSleeper, Pretty dirty.....
This should cover though;
Name:  Briggs Auto Choke Spring.JPG
This spring pulls the vane to close the auto choke, Once the engine starts the vane moves and opens the choke for normal operation.....
Old 04-05-13, 06:39 PM
cheese's Avatar
Received 134 Upvotes on 123 Posts
The spot where you put the question mark... that's where it goes. It doesn't connect to the air vane at all. It pulls the choke closed. The air vane moves the choke open once the engine starts.
Old 04-05-13, 07:05 PM
H
Perfect! Thanks to both of you. Guess that means I have to cut grass now
take care,
Andy
Old 04-13-13, 11:00 AM
H
Just got the spring yesterday and that picture helped a lot. It was exactly as you showed it. Just cut the grass and it worked like it always had. Thanks much!
Guess I do need to clean that engine. Any thing anyone would recommend to clean it?
Thanks again,
Andy
Old 04-13-13, 07:08 PM
31YTech's Avatar
Hello Andy,
Good to see you got it going, Any automotive type engine degreaser and a water hose will do the trick.....
