how to remove pulley nut from mower deck to replace spindle
breakingorbit's Avatar
04-24-13, 06:30 AM   #1
Hello all, I have a Poulan Pro riding mower that needs new spindles. I replaced one with no problems. The blades are star patterns so I left the blade on, blocked it from turning, and the pulley nut came right off.
However, one the other one, the one that really needs replaced, the star pattern on the bottom of the spindle, is wore out. Completely. I cannot get the blade tight enough to be able to loosing the nut on top. It either keeps turning, or if I try to hold the bottom blade bolt, it loosens the blade bolt back out.
Any suggestions to keep it from turning?
Thanks
04-24-13, 08:53 AM   #2
FYI, I got this fixed. after struggling yesterday for an hour and a half, and working on it this morning, I finally got it.What worked for me, was taking the lock washer, and bending it back out pretty good. Then when I put the blade back on, the washer had enough pressure, to let me loosen the pulley nut on top. So apparently my lock washer was weak, lol
Hope this helps someone else
Orbit
