Mower goes EXTREMELY slow!
Old 04-26-13, 03:27 PM
A
Exclamation Need help because crafts man wouldn't help
I have a craftsman LT2000 and it's got a gas pedal and no matter how far I press down on it, it still goes about the same speed as it is when I barley push down on it! I've had the mower for about 3 years got it new. It also starts to get even slower as I keep mowing.
Old 04-26-13, 04:21 PM
cheese's Avatar
Received 131 Upvotes on 121 Posts
Could be the belt slipping or the transaxle getting weak. I assume this is a hydro? A model number might help us know what you have better.
Old 04-26-13, 04:42 PM
Gunguy45's Avatar
Super Moderator
Received 6 Upvotes on 6 Posts
Does the engine speed up when the throttle is moved from idle to higher speeds? Just wanted to eliminate that.
Old 04-26-13, 06:02 PM
A
It does speed up some but probably from about in the middle to full speed on the throttle it goes about the same speed but still it's not the throttle for sure. Ill find out the model for you and what belt would affect the speed?
Old 04-26-13, 06:34 PM
cheese's Avatar
The transmission belt.
_____________
Old 04-27-13, 07:16 AM
A
I thought the transmission belt is for the blade?
Old 04-27-13, 09:27 AM
cheese's Avatar
That would be the blade belt.
