lawn tractor blades wont engage
Received 0 Votes
I have a craftsman ys4500 lawn tractor., its 6 years old. after first post winter run the blades are not engaging correct. I just changed the belts and same issue.
So when I moved the mowing lever(to engage the blades) it used to make a thud and vibrate a touch and you knew the blades were engaged. I distinct thud and there was no question the blades were spinning it was like driving a tank with the blades spinning.
Now the blades do spin but no thud at all its whisper quiet and the blades spin up and sound like a washer machine on the spin cycle. no vibration at all I cant tell there even spinning unless I look under it. Maybe like turning on a large fan.
Its absolutely not correct but I don't see any issues anyplace under the deck
Received 0 Votes
They spin and could probably cut grass but they sound like they might fly off the mower. Picture the sound of a CD spinning up in a drive. its nothing like it was last season.
They would be fixed to the drive spindle with a single center fixing bolt. Check to make sure that's tight and the blades disengage with the correct lever position. If it is and it cuts grass, I wouldn't worry about the rest.
