Ford 2000 tractor . hydraulic lift won't come up.
Old 05-01-13, 06:22 AM
B
Any advice:
Ford 2000 (1963) tractors hydraulic lift will not come up??
Any advice will be appreciated.
Thank you.
Old 05-01-13, 06:36 AM
P
Received 1,845 Upvotes on 1,652 Posts
Have you been doing any work on it?
What does the fluid look like?
Is your tractor gas or diesel (3 or 4 cylinder)?
Old 05-01-13, 06:42 AM
A
Received 73 Upvotes on 66 Posts
Was it getting a bit jerky or unresponsive before it stopped working completely? If so, I would suspect that the transmission is due or past due for an oil and filter change, as opposed to a mechanical failure. There is a lot going on in there, and shavings, even from the time of manufacture, can continue to float around in there for a long time before accumulating in the filters or screens. If it is up to par in regard to this mainetenance, then I probably would be looking at the rock shaft control valve. Particularly if this is the case, you will probably want to get your hands on a manual, because there are undoubtedly bypass valves, etc. in that system, any of which may have a burr in them.
Old 05-01-13, 12:48 PM
Received 754 Upvotes on 659 Posts
I'd get a repair manual if you don't already have one. Tractor Supply sells them along with a host of online vendors. Have you checked the fluid level? When was the last time the lift worked?
Old 05-01-13, 04:14 PM
chandler's Avatar
Received 9 Upvotes on 8 Posts
Check the fluid level with everything at rest.
Oops, you don't have a choice, do you.....my bad.
