Kohler Command 17.5 stalling
Old 05-03-13, 05:12 PM
W
My lawnmower starts up fine, runs for a couple of minutes and then dies. As she is stating to die if I put the lever to choke she picks up and runs a little longer and then dies. If she sits for a little while she will start up again but only for a couple of minutes.
I pulled the fuel filter and it's fine. I checked the spark plug and it's fine as well.
Any suggestions?
Old 05-03-13, 05:38 PM
Received 1 Upvote on 1 Post
Pull and rebuild the carberator and it will be fine,
Old 05-03-13, 06:16 PM
W
The vent hole on my gas cap was clogged, used a pin to unclog it and problem solved.
Old 05-03-13, 06:19 PM
31YTech's Avatar
Hello whalerbob,
Before pulling the carb apart loosen the gas cap and see if it will continue running, If so check the cap vent for obstructions.....
Good Luck
EDIT; Guess I need to type faster !
