Toro Lawn mower support
I bought a new Toro lawn mower from Home Depot and wanted
to purchase spare air filter.
Home depot doesn't carry the air filters here,the local dealer can't,or won't help me,I can't reach Toro by phone,and their web site is useless,and keeps sending me back to some other page,or whatever..
Now, i know there are you folks here who probably know how i can get a little old air filter.
Any help?
Thanks
Any help?
Thanks
Hello daswede,
You can order parts directly from Toro here; Find Genuine Toro Parts
Just enter your machine model number then look the part up and add it to your shopping cart.
Or you can purchase at any of these webstores just to list a few;
OEM Parts
OEM Parts
OEM Parts
OEM Parts
OEM Parts
Good Luck
OEM Parts
OEM Parts
OEM Parts
OEM Parts
OEM Parts
Good Luck
31YTech......No luck in the search.
aj-allen ....Toro model 20370, 22" recycler,front drive,Kohler Courage XT 6.5 h.p. engine.
I can believe some dealers get miffed if you don't buy from them. The only air filters he had was the paper pleated ones that didn't fit my model.
Got it daswede,
Kohler part # 14 083 09-S
I failed to remember.....
Any time you need a engine related part you need to use the engine model and spec numbers and search under Kohler instead of Toro......
Genuine Kohler Part: 14 083 09-S - ELEMENT, FOAM FILTER
Received 0 Votes
Toro Mower 20066 gear-pinion replacement
I am replacing the right rear wheel of my Toro 20066 (280021283). The gear-pinion (#105-3040) has an "L" on one side. When placing the gear-pinion back, should the "L" be on the inside or the outside as I stand behind the mower. Again this is the right side as I stand behind the mower? Thank you.
