Honda XR2600 - DeVILBISS PUMP A14292 - Need Head Assembly
Old 05-14-13, 07:47 AM
Is there anywhere I can just purchase the head assembly instead of the whole
This is a link for the whole assembly I need. But the part thats cracked is just the head. Which I can't seem to find a part number for either.
PUMP OIL FREE RADIAL 2600 PSI MAX
Thanks Jon
Old 05-14-13, 06:25 PM
31YTech's Avatar
Hello Jon,
You likely can't find a part number because it's not sold separately, However I did find a used one HERE. But before I'd spend that much for a used one to repair your pump, I'd look into new replacement pump such as THIS .....
Good Luck
Old 05-14-13, 08:41 PM
Thank you I took a look at it, and I do not believe I need a new pump just that one piece.
Old 05-15-13, 04:03 AM
GregH's Avatar
Super Moderator
Received 66 Upvotes on 61 Posts
"The A14292 is the oil free radial strap pump that was used by Ex-Cell as a low cost entry level pump."
Parts are not generally available for inexpensive offshore components.
The reason being that when these units fail under warranty they are cheaper for a maker to replace rather than repair.
If you are determined to attempt a repair perhaps someone has a unit for parts on eBay.
