Gas won't stop - Nikki Carb on 10HP Generator
Had an issue not getting gas to the carb on a Coleman 10hp B & S powered generator. Cleaned, new gasket, installed - now I have fuel - more than i need. Gas turned on - and is trickling out of the carb, constantly. Took carb apart again to ensure float and spring were installed properly - Yes, they are, but gas won't stop. Carb is a Nikki.
What do I need to do?
Any help would be much appreciated.
Regards,
BJ.
Regards,
BJ.
If this carb has the plastic insert in the carb, replace the o-ring between the fuel inlet on top of the white insert and the carb body.
