Craftsman tractor with Kohler cv730 engine
Received 0 Votes
Cut the grass 2 days ago and all was well. Yesterday I hooked the sprayer tank to the tractor and started to spray the apple trees. I was about 1/3 done when the engine shuddered and quit. It turns over fine and there is spark at both plugs. The plugs however are dry. The fuel pump is a vacuum feed I think as it is a round disk about 1 or so thick with 3 hose ports. The gas is going through the filter but seems to not be making it to the carb and hence to the cylinders. Is there an air leak? It is a 35hp engine on a 48 inch cutting garden tractor of about 10 years in age.
Confirm that the pulse line from the engine to the fuel pump is connected at both ends and does not have any holes or cracks but it sounds like you need a new fuel pump. I'm not sure if you can replace the diaphragm in the pump but they are usually pretty inexpensive to just replace the whole pump.
Received 0 Votes
The fuel filter is good. I put the new fuel pump on this morning with no luck. It still did not pump gas out the disconnected hose to the carb. If I take the pulse hose off the engine and lightly blow into it gas seems to flow through to the carb hose.
Received 0 Votes
I took the pulse off and checked. No cracks or leaks. I took all the hoses off and checked them with the same result. When I took the hoes between the fuel filter and pump off and held it low the gas ran out in a solid stream. It is just not getting gas to the carb with enough pressure to fire. Could it be the hoses are not sealing because the clamps are worn?
Low oil, on an incline, no crankcase pulses to operate the fuel pump... I think your fuel pump is fine, and the least of your problems. I think your engine is blown. Does it seem like it's cranking/spinning faster than it used to? Check for compression. See if there is any at all.
#21
Depends on how bad it is, but I'm sure both piston rods are broken, the crankshaft and camshaft may be harmed, the governor is likely ruined, and there may be a crack or hole in the block. The only way to know for sure is to take it off, open it up, and see what it looks like. Just for the heck of it, pull the spark plugs and put a drinking straw in each plug hole and turn the engine. Do you feel anything contact the straw and push it back out the hole? This will tell for 100% sure if it's blown. A hung open valve won't stop the fuel pump from operating.
#23
No, not necessarily. The main thing you want to look for is crankshaft diameter and length. There are dozens of engines that will fit, some may require changing parts from your old engine, some may not, some may have a different wiring connector in one place or a different throttle or choke hookup, but the engine itself will be the same in most all cases if they are in the same model series and same crankshaft length and diameter.
#24
Received 0 Votes
Thanks for all the help. I have decided to dump the tractor - motor and all as it is 11 years old and I have been replacing pulleys brackets etc. I have also replaced the mower deck as weldments on the original cracked and fell off. Time to move on.
