Tecumseh Carburetor Replacement
Received 0 Votes
I have a Tecumseh TVS90 engine that calls for a Tecumseh Carburetor 631581 that is no longer available. Any suggestions for a replacement carburetor would be appreciated.
Thank you,
Alan
Thank you,
Alan
You can still get a carb rebuild kit. Most likely it is just a clogged jet and cleaning the carb will correct whatever problems you are having. You can try just pulling the carb and cleaning, but sometimes you can not get the bowl seal back on. It tends to expand and you can not get it back into alignment so it needs to be replaced.
