Murray tractor trans. Problem, 5-sp. stuck in 1st gear.Help!
Received 0 Votes
80's murray GT with 5-sp trans, stuck in 1st gear! Help!
Received 0 Votes
Thanks, bought 2 years ago for 200, needed it to tow trailer, and attm., runs daily, body,engine in great shape. Stored inside winter, usually out summer.(need room for my cub gt 3100). Tried tapping U shaped bracket att. To trans,no luck. Thanks for any help. Murry 11hp, model 2-36503, #1265.
Ok, thanks, that helps. I was thinking the needle bearing in the top of the tranny might be rusted up, but since it has been working often and recently, I'd say not. I think the shift keys in the trans are bent, damaged, or broken.
Seems like my grandpa had one of those, I remember him saying that the transmission seemed like it needed lubricant, but no way to add anything, so he tapped a hole into the transmission, added some lubricant, and plugged the hole. Not sure if yours is similar or not.
Received 0 Votes
Murry trans.
Don't think i'll drill any holes,but thanks. Cheese, bent fork? Sounds terminal! I could just use 1st and take hours to go an acre. Think I could fix it? Take case apart? Thanks Cheese
Received 0 Votes
Murray tractor
I have the identical tractor which is a 1982 model. If you phone 1-800-661-6662, they may be able to help. Mine still runs like a finely tuned watch. I had to get an idler pulley for the belt recently, and got help at that number.
Jimbob07
Jimbob07
