John Deere LA145
Old 06-05-13, 12:36 PM
D
John Deere LA145
My friend's JD LA145 will go neither forward nor reverse. He did hit 'something' last time out, so
I'm thinking he broke something under the shroud. I'm told they're belt-driven.
Nothing absolutely nothing about riding mowers myself, I'm asking for an experienced
opinion.
He has no online access, so i'll print out the answers here on DIY and drive over.
Many thanks ahead of time. You guys always come through
Jim in MA
Old 06-05-13, 05:19 PM
Received 1 Upvote on 1 Post
Check the belt that runs the hydrolics, no belt no go.
It's way up under the main frame.
Old 06-05-13, 07:40 PM
cheese's Avatar
Received 122 Upvotes on 112 Posts
Yep, most likely either the belt came off, the release lever that you move to be able to push the mower got pulled, or he took a rear wheel off to fix a flat and let the axle key fall out.
Old 06-06-13, 01:41 PM
D
RE: La145
RE: the JD 145; he got the thing up on end and said there's no belt. It's got a shaft
"from a pedal" directly into the trannie.
I'm going to see if I can d/load a manual for this thing.
Can you recommend a website?
Thank you all
Jim in MA
Old 06-06-13, 03:59 PM
http://jdpc.deere.com/jdpc/servlet/c...&model=+LA145+
Here is a link that shows the belt you need. This is from my JD dealer in West Plains, MO.
You can just go to a JD website and type in your model number, these belts are quite pricey. Good Luck
Old 06-06-13, 08:02 PM
cheese's Avatar
That shaft is not what drives the tranny. There is a belt driving the tranny.
