Craftsman mower dies after running for 3 - 5 seconds (starts only when primed)
Old 06-08-13, 05:05 PM
I have been trying to fix this mower myself, on and off, for a couple of weeks. At the start of the season the mower started right up and worked great. I was mowing the lawn and suddenly the mower died. Thinking it was out of gas I add more only to have it not started. I primed the engine and it ran for about 5 seconds, the kills. I have replaced the spark plug, drained the gas tank, ran gas through the fuel line, cleaned the air filter, even looked at the carb, which looked good. Still the mower only starts when primed and runs for 3 - 5 seconds. I am out of ideas. Anyone else help me out?
Old 06-08-13, 06:33 PM
31YTech's Avatar
Hello Stephen,
Sounds like the main jet is clogged with a piece of trash, The main jet is the float bowl retainer screw. Remove the bowl screw and you'll see two holes in the side and one smaller hole in the center, Use a small piece of wire and make sure all three of these holes are fully open then try starting again.
Good Luck
Old 06-08-13, 09:01 PM
Thanks for the reply - just pulled the screw from the float bowl, ran a small piece of wire through the holes, and into the top hole, multiple times. Still getting the same result. other suggestions?
Thanks!
Old 06-08-13, 09:09 PM
Received 1 Upvote on 1 Post
Remove, clean and rebuild the carb. with new parts not just look at it.
Old 06-08-13, 09:11 PM
G
Received 28 Upvotes on 27 Posts
You probably missed the hole that is the problem, it is almost invisible especially id the nut is dirty, I use the wire from a twist tie to clean it, refer to the pic below. Have a good one. Geo
