Gas in the oil
Old 06-16-13, 03:42 PM
Geochurchi's Avatar
Received 159 Upvotes on 145 Posts
Gas in the oil
Hi All, I have a 13 HP B/S engine which runs fine except for the fact that if I forget to shut the gas valve off the crankcase fills up with gas,how do I fix this problem?
Engine Mdl# 28M707. Type. 0122-01. Code. 960430ZD.
Thanks
Old 06-16-13, 04:02 PM
Gunguy45's Avatar
Super Moderator
Received 6 Upvotes on 6 Posts
I think I can answer this one. Rebuild the carb (including needle valve and seat) and adjust the float correctly.
That and put a Dymo label above the key that says "Turn off the gas!"
Just kinda messing with you. I know some equipment has a solenoid that cuts off the gas....but you didn't tell us what type of machine the engine was in.
Old 06-16-13, 04:03 PM
Received 1 Upvote on 1 Post
Should not have to shut it off everytime.
Your floats sticking in the carb.
Remove clean and rebuild with a new kit.
Also going to have to change the oil and remmove the spark plug and pull it over a few time to flush out the extra gas.
Old 06-16-13, 04:33 PM
Geochurchi's Avatar
Thanks, I thought that would be the reply any idea where I can get instructions on rebuilding a B/S.carb?
Thanks
Old 06-16-13, 04:42 PM
Gunguy45's Avatar
Super Moderator
Last time I rebuilt any card...the kit came with good instructions. And you do want to buy the whole kit....why skimp?
Old 06-17-13, 07:26 AM
Once you get it apart your going to find there built so there's only one way things can go.
There's pins that will only line up one way with the gaskets and metal plates.
Just make sure to clean off any of the old gaskets left on the metal.
