Gas tank leaks
Received 0 Votes
Gas tank leaks
Hi everyone, I have a Sears power washer powered by a Briggs 4.5HP gas motor. I hadn't operated it for the past 7 or 8 years but I need it now. Yesterday I took from the spot where it was stored, checked the oil and gas tank. The oil was full but the gas tank was empty. I figured, what the heck, I'll put some gas in it and see what happens. Well, as soon as put some in, I noticed the fuel line was full of cracks and leaking like a sun of a gun. And, I also noticed that there was gas coming from the gas tank somewhere. But, I tried to start it anyway. It fired right up on the second pull. Surprised the heck out of me. However, I need a way of fixing the gas tank. The leak is at the seam where the 2 pieces come together. Does anyone know what I can use to apply to the seam to plug the leak that can handle gasoline? The gas line I can get anywhere. Thanks, Roger
Received 0 Votes
Sorry. I should have included that it is a plastic tank and I was afraid the only solution to the leak is replacement of it. I'll go to Sears parts direct and see what kind of money they want for a plastic tank.
Thanks for the replies, everyone. I appreciate you taking the time to answer.
Roger
Roger
Received 0 Votes
It's hard to believe they want nearly $40.00 for a plastic fuel tank and fuel cap.
Perhaps you folks can find it cheaper somewhere?
Sears 4.5HP Briggs & Stratton engine.
Model of Pressure washer is: 580761010
Thanks again for our help and suggestions.
Roger
Roger
Received 0 Votes
Model number off engine will be the big helper here or if you have the part number. Type in Briggs and Stratton Gas tank on e-bay and it will bring it up. Model number on engine will be on recoil housing on a little tap of metal just above muffler, if memory servers me correct.
Received 0 Votes
Part number 699374 and there are a TON of these on e-bay, here's a link to one under $25.00.
Briggs Stratton Gas Fuel Tank Lawn Mower Lawnmower Pressure Washer 699374 | eBay
Good luck,,,,,,,,,,,,,,,,,,I hope the post will stay, just help the guy out.
