john deere gt275 ,mower want stay engaged
Old 06-22-13, 07:33 PM
G
On my gt275 when I pull the switch to engage the blades they have started to shut off after a few seconds .This has just started happening more frequently.
Old 06-22-13, 08:21 PM
cheese's Avatar
Received 120 Upvotes on 110 Posts
Is your battery dead?
___________________
Old 06-23-13, 06:22 AM
31YTech's Avatar
Hello gswillis,
As Mr Cheese mentioned, Check your battery condition and charging system with a multimeter.
If both test good check the adjustment on the PTO clutch as below;
There are three slots in part # 5 to insert a 0.012 feeler gage, Adjust the three nuts until you feel a little drag on the gage. Move each nut only a little at a time and keep checking because tightening one nut will tighten the gap on the other slots.
Good Luck
Old 06-23-13, 04:38 PM
G
Mr. Cheese thanks for your reply.By the way its a brand new battery .Where is this located on this shaft. Is it on the mower deck?Thanks for your help.
Old 06-23-13, 04:55 PM
31YTech's Avatar
gswillis,
The PTO clutch is located on the end of the engine crankshaft.....
Old 06-28-13, 06:08 PM
G
Im just getting around to checking the 3 slots in #5 .Exactly where do I put the feeler gauge?
Old 06-28-13, 06:47 PM
cheese's Avatar
When you see the slots, there is a thin place between the clutch plates that you put the feeler gauge in and adjust the nuts until you obtain proper clearance.
