Ride-On Mower Deck Lower On Driver's Left (Pictures)
Old 06-25-13, 06:46 AM
It appears you're missing one of the lift linkages--but the pictures are too blurry to know for sure. In order for your deck to remain parallel to the ground it must be hanging from 3 or 4 links, slotted so the deck can slide up to clear an object.
They often are held in place by a loose dowel pin & spring clip. The clips get snagged on things & disappear, then the linkages can fall off & vanish into the grass.
