6hp Briggs + Stratton fuel problem
Old 06-25-13, 05:18 PM
D
dam
dam is offline
It doesn't seem to be getting fuel. I pulled the carb off like 4 times and sprayed it out with carb cleaner. Took the needle and float out and ran a pin through all holes. Everything's seems clear. Bowls filling up with fuel. It will run with a shot of starting fluid for a second. One thing I noticed is the primer bulb doesn't seem to be picking up fuel. Any ideas?
Old 06-25-13, 05:21 PM
Clean the bolt or jet that holds the float bowl on. It has three holes in it, two on side and one in center.
Old 06-29-13, 04:28 PM
Put 2 gaskets on the air cleaner,in front of the carb. where the air cleaner bolts to the carb.The air cleaner can warp causing the primer bulb not to work.Part #795629.Hope this helps.
Jerry
Old 06-29-13, 06:29 PM
Good point Jerry,,,,,,,,,,,,,,,,,,,,,,
Old 06-29-13, 06:54 PM
cheese's Avatar
Received 122 Upvotes on 112 Posts
Also if the bowl gasket is missing or not fitting well, the primer won't work.
