Ryobi Gas String Trimmer,carburetor
Old 07-21-13, 07:55 PM
R
I'm trying to get a diagram of the gasket configuration on a Ryobi Model RY30020A,S/N AH3141014 11-05? never figured there were so many gasket's in this weed trimmer.Yes I took it apart and don't remember how to put it back together.Any help would be apprciated
Old 07-21-13, 09:07 PM
cheese's Avatar
Received 131 Upvotes on 121 Posts
I don't know what carb is on that, but on the side with the needle valve, assemble the gasket on forst, then the diaphragm with the disk side facing the carb, then the cover. On the other side (fuel pump side), assemble the flat diaphragm, then the gasket, then the cover.
Old 07-21-13, 09:27 PM
R
Thank you cheese, I also took your advice on the 12-5 briggs and ordered new valves. Thank's again for your help.
